- Sat May 21, 2011 2:41 am
#256146
I have a 94 civic hatch with obd1 pr4 and b18a. I have a check engine light and i found the ONLY 2 pin connector in the kick panel, it is a blue connector when i jump the connector the check engine light shuts off and the srs light flashes, when i plug a p06 in and jump the connector the cel flashes. I have searched around and had no luck with this issue. anyone else experience this?
A long flash stands for 10, while a short flash stands for 1.
Example; if you have 2 long flashes and 2 short flashes, you have a code 22.
1994 Honda Hatchback CX - B20 vtec turbo - Toy
1996 GMC Z71 - DD
