- Sun Apr 10, 2011 10:29 pm
#249581
I have used the search function and found nothing that would help, I also found a couple diagrams floating around that werent even close to what my wiring is so here goes. I have obd1 harness and obd2 distributor, now some people say its straight forward and all the colors match, on mine thats not close a couple match but thats it. On my engine harness the colors are as follows: org, org/blu, blu/grn, yel/grn, white, white/blu, blu/orange. and the large gauge black/yellow wire and the small gauge blue. Now on the obd2 plug im wiring to the obd1 harness i have: yel/grn, dark blue, grn, yellow, black, red, white , light blue, then the heavy gauge black/yel. I need the correct diagram to wire this and make it work. If anyone could help that would rock. Sorry about the long drawn out post but im lost and i cant find anything anywhere that helps.
Passwordjdm also sells one....
I've made my own before too though, the colors may not always match but there order and where they pin into the harness is the same and they go into the same order
PANDA CREW No.20
PANDA CREW No.20
