ECU, Wiring, Sensors
By Method
#221051 there is a blue jumper under the dash passenger side. use a paper clip and jump it out. turn the key to acc. it will start flashing, if you have code. a long flash equals 10, and a short flash equals 1. for instance if it flashes long, long, short, short, short, the code will be 23.
By NOCLUE
#221087 correct :woot:
By NOCLUE
#221088 so it is 15 and 41 ?
