ECU, Wiring, Sensors
By JUICE
#216620 supposedly you can re-solder the connections..
is it doing the classic crazy speedometer or is it all jacked up?
By Adrian91
#216633 spedo is way off, says in going 21 in idle, 60 when im goin 40. Im not sure if RPM is accurate, might be slightly off. Fuel dont work, and temp dont work
By 95c1v1c
#216640 Once you pull it out check the main connectors for corrosion. I have done the diy and re-soldered the connections and all is well except the fuel....might be the sender in the my tank, shows slightly lower than actual quantity.
