ECU, Wiring, Sensors
By J'95
#180418 Hi guys need some help here, my running and my head light just stop working on me, checked the fuse box and there's no power there either i also checked the eng. bay fuse box it looks ok. please any help would be nice right now.
By J'95
#180467 Just came back from the junkyard got me a another lever and still no luck!!
By Apexracing
#180545 fuse or relay then
By J'95
#180604 Thanks meng, will try again today
By nickbrungard
#183966 If you are apt to try some hands on wiring troubleshooting I can get the parking light and headlight wire colors and you can source them with a fused jumper to see where the problem lies. switch, relay, short etc.
By J'95
#184118 Anything to help would do just great !!!
By nickbrungard
#184137 I will try to get the wire color and info for you monday or tuesday. Shops closed for the weekend.
#184177 Do you have a multi-meter?
Download the manual from honda hookup and then find the troubleshooting flow chart for the headlights.
By J'95
#184186
suspendedHatch wrote:Do you have a multi-meter?
- I took my dash out thinking thinking i might find burned or loss wire.
By Classiccarsrule85
#184187 umm....did you happen to check under the engine bay there are two boxes either side with a bunch of black wires going to them.....they may have gotten loose (ground connections) happened to me a bit back since there seems to be no power there may not be a complete circuit....
#184380
That was a complete waste of time and in no way related to my suggestions.
By Apexracing
#184383
not quite a waste because if he hasn't taken it apart before he now knows how too :)
By J'95
#184588 Put everything back, did not find any burnt or loss wires, changed all the fuses in the eng. bay and under the dash and then for some strange reason my light are back on, shit no idea...
By nickbrungard
#184608 Was probably just a bad connection on one of the plugs. If it happens again try one at a time and you may be able to isolate the problem. Can even happen with the fuse connections at the fuse box. Good to hear its working.
