- Mon Mar 08, 2010 9:47 am
#179833
I have a 1995 civic vx.
The speedometer always works during the first 5-10 minutes of driving, however when the engine warms up, the speedometer begins read incorrectly..
For example... Cruising at 65mph when engine is cold- all is normal.. 5-10 minutes later, speedometer will begin to drop to 40mph and stay within that range..
The guage will no longer read correctly until the next morning- again for about the first ten minutes of driving..
Once in a blue moon, the check engine light code 17 would come on after slowing down from high speed driving
What ive replaced:
3 clusters , new speed sensor, replaced speed sensor harness twice, bypassed vss wires in the harness and ran new wires directly from vss to speedometer cluster- still problem exists.
I reinstalled the vss back to the orig harness and did continuity tests and dc voltage tests..
With multimeter. I connected one end to the yellow/blue wire of vss connector and the other end to the black/yellow wire of speedometer harness.. I get full continuity.. BUT i am also getting continuity on all the remaining pins of the sppedometer harness too! (is this normal?)
i then checked continuity from the yellow/white wire of the vss harness and the yellow/blue wire of the speedometer harness and get full continuity- i checked all the other pins on the speedometer harness and get no readings...
I then did a dc voltage test...
With ign on and mutimeter on dc10, speedometer harness connected, i grounded the multimeter and the positive end connected to the yellow/white wire of the vss plug, i get a voltage reading of about 7v..
I pulled the vss assembly out of the transmission and inspected the gear teeth of the vss housing and it looks good
i inspected the plastic gear in the transmission that is visible through the hole where the Vss mounts and i didnt feel any missing teeth..
I feel drag on the vss when i turn it, not much drag on the gear in the trans..
What ive replaced:
1994 Nissan truck XE
1995 Civic VX (53mpg)
1995 240SX SE
2000 Infiniti G20 touring
1995 240SX SE
