ECU, Wiring, Sensors
By Apexracing
#149357 hey guys i my dx sedan has them and im looking to transfer them over to my cx hatch, ive already replaced the switch on the steering colum what else to i have to replace. and where can i locate it on my sedan. thanks guys.
By asianrob
#149491 may need to replace the wiper motor too..i am not sure tho
By Apexracing
#149856 I'm coming to a conclusion that there is no wiper relay i cant seem to find it any where. and i cant seem to find any articles pertaining to its location or such. and its frustrating.
By Aztec Adobe
#153581 Have you tried swapping over the integrated control unit (back side of underdash fusebox) from your DX to your CX? If you've already swapped the intermittent wiper switch over, the ICU might be all you need to get intermittent up and running on your CX.
By Apexracing
#153585 no but ill try that. thanks!!
By d-mon
#153624 the intermittent wiper switches go out alot.
i replaced mine once, and its already broken again.
only used it about 4 times
By Apexracing
#153672
d-mon wrote:the intermittent wiper switches go out alot.
hmm worked fine on my dx sedan, i'm just trying to move them over to my cx hatch.
#155142 Aztec Adobe called it. Pull the black box off the back of your under dash fuse box and swap it over.
No need to change the wiper motor.
