ECU, Wiring, Sensors
By hardspike
#139755 93 CIVIC SI.....
hey i have a complete b16a2 engine and dash harness,wondering if i can use all this and run an obd 1 ecu chipped to run this set-up ???
It's going into a 93 civic,,,came outta a 99 civic si
By asianrob
#139787 easiest way(in my opinion) is to take the harness off your existing motor plug it all into the B16, swap out Dizzys for an OBD1 dizzy (you can use GSR/B16/) or repin it for obd1 (in my opinion is kinda hard)
i think you may need to wire knock i'm not sure its been a while since i touched anything..
after that everything pretty much plugs and plays use P30 ECU or chipped P28 or even P72 (it may be more richer than others)
