ECU, Wiring, Sensors
By ThisEarl
#138705 Im looking for the chime that beeps when the door is open and the key is in the ignition.
I havent looked too hard but Ive tried to listen for it but everytime I think im close it sound like it moves lol....
Pictures would be amazing but just a general area would work too.
Thanks guys....
By 93cxhb
#138708 if i remember right that anoying little thing is up under your dash on the drivers side behind the fuse panel . but get a second opinion before you star taking stuff apart . good luck
By ThisEarl
#138794 That sounds right, Im going to go check....
#139330 Ok, on the back of your under-dash fuse box there's a black box snapped in. You can pry it out with a flatblade. It's pretty tough to get out. Then crack it open and you'll see a small speaker on the circuit board. You'll need to heat up the two solder points while applying slight pressure between the speaker and the circuit board. It's not super delicate or anything but if you go in with lumberjack force you could break the circuit board. So just like wedge your flatblade in there and heat up the solder points with a soldering iron (cuz I know you're probably not going to get a de-soldering tool). Pop the speaker off and put everything back together and you're good. No more, super-annoying key chime! One of the first things I did to my Civic and to my DC Integra.
By ThisEarl
#139336 Thanks man, good thing you told me its delicate or I would of just pulled it off with a knife lol
