ECU, Wiring, Sensors
By pcbabb
#249336 SO I swaped a Y8 into a 91 Wagon 0bd0 dpfi to Obd1 mpfi. running the p28. the car will spin over but its flooding out #4. I've swapped the injectors for others that I had as well. running obd2 dizzy and injectors. Using a Boomslang obd0 dpfi to 0bd1 conversion harness. Any ideas as to what the problem could be?
By pcbabb
#249797 test my ecu today on a known running car....and it works. I have narrowed it down to the injectors. I pulled the rail with the injectors still attached and they are not pulsing. Any idea.
By Classiccarsrule85
#249822 now am i reading this right? you mentioned obd2-dizzy and injectors am i to assume you used obd2 injectors with a obd1 ecu that definately wont work you will want obd1 injectors with the obd1 ecu dizzy really dosent matter but injectors are a bit different i beleive....
By pcbabb
#250080 so the boomslang wiring diagram reversed the crank and cam sensors in the dizzy thus causing the injectors not to pulse. After pulling diagrams on obd1 and obd0 I was able to trace the wires. She runs like a top now!!!!!! btw I felt so silly driving a ef wagon. Feels kinda like a mini van
By TrailerTrash
#250094 the wagons are badass dude! pictures now :x
