ECU, Wiring, Sensors
By eghatch27
#69733 I just swapped to a D16z6 in my 92 hatch, its a manual with a p28 ecu (converted). It was throwing CEL #14, IAC Valve (Idle Air Control). I replaced the unit, and reset the ECU.... and the code is still there. I'm wondering if the grounds are bad, going to the IAC, but im not sure what grounds to check.
Anyone have any idea how to fix this issue im having?
Thanks
