ECU, Wiring, Sensors
By turbosedan717
#214135 i posted on teal's thread but no ones gotten back yet. i finished my chassis tuck and when i put my battery in to test everything only my driver side electronics work. i don't know what this is and i need some help. everything on the driver side works, but nothing on the passenger side does. i've checked all my fuses but i think it may be something with the under hood fuse box.
By Classiccarsrule85
#214155 did you check all your grounds? that little box up front with a ton of black wires caused me to lose my headlights when they werent tight and partial dimmness of other electronics....
so yea check your grinds....
By turbosedan717
#214526 thanks for input. i'm gunna go check that now, but i had another worry that when i took a test light to all the prongs to the plugs in my fuse box they had a charge except for the one that has a few wires from my passenger side. is that a fuse box problem?
