ECU, Wiring, Sensors
By Classiccarsrule85
#208786 youll have to extend some wires but you could use the obd1 harness if your useing the obd1 dizzy
Classiccarsrule85 wrote:youll have to extend some wires but you could use the obd1 harness if your useing the obd1 dizzy
x2
Reuse your z6 wiring harness. You will have to run wires for your knock sensor(or disable it with tuning) and extend the o2 Wiring from front to back.
You will need a OBD1 B16 or B18c GSR Dizzy. You can take the obd1 electronics from your z6 dizzy and put them in the obd2 b18c dizzy. The Electronics swap over with no issues as long as you keep the same center shaft(sohc vs dohc). If your going to buy a new one 94-95 Delsol VTEC Models came with USDM b16's as well as the 94-95 Integra GSR has the dizzy you want if your going to buy one from an Autozone styled store.
