ECU, Wiring, Sensors
By stubrun
#178606 hey guys as you know im fitting a b16a into my ej2 coup, question i have is, will the auto harness run the manual b16 if i add the wiring for the vtec and jump the wiring for the shifter in P etc.
By stubrun
#178609 forgot to add i am using the full b16a engine loom and as the d15b7 runs multi point injection the car loom will plug and play
#178652 As long as you run wires for vtec and knock sensor to the ecu, and run the reverse wires to the transmission then yes the wiring will work just fine.
By stubrun
#178668
chrono404 wrote:As long as you run wires for vtec and knock sensor to the ecu, and run the reverse wires to the transmission then yes the wiring will work just fine.
awesome, cheers mate
