ECU, Wiring, Sensors
By fhukingviet
#101790 Recently, My 92 si cabin harness burned due to something with the horn (basicly where the burn started from) all the way to the heater core area. Now that im searching to buy another cabin harness, which would be interchangeable to use with, i woulddnt mind if the sunroof and power mirrors dont work but just looking to save money, like can i use the CX Model or like DX from coupes? Also any way i can find out if other electrical stuff like ecu or fuel pumps were damageed . thanks
By asianrob
#101819 why waste your money on those cabin harness?
you can always get an EX harness and go from there. it be the same differences except it would be wired up for PW, PL,PM, Sunroof, and what ever other options the EX had the Si didnt.
By fhukingviet
#101821 those harnesses would be alot easier to find, would they work and start my car up? with the old burnt harness, it didnt turn a thing on except the sunroof , power mirror and ignition beeping when your turning the key.. i could possibly rewire the power mirrors and sunroof since those still work
By fhukingviet
#101950 anybody! helppp this is my first car
By asianrob
#102018
fhukingviet wrote:those harnesses would be alot easier to find, would they work and start my car up? with the old burnt harness, it didnt turn a thing on except the sunroof , power mirror and ignition beeping when your turning the key.. i could possibly rewire the power mirrors and sunroof since those still work
it would be alot easier to get it already wired up.
those harnesses arnt that hard to find.
you can use the 4dr harness, the only thing is that youd have some extra wires laying around for the rear doors.
you can use any model 92-95 harness but like stated youd have to wire up the other stuff if you use the CX/VX/DX stuff.
and yea you could possibly rewire it if you know where to look for the wire.
By fhukingviet
#102101 would using the del sol harness usuable, i actually found one for 50$ but didnt buy it yet... it does have power lock and mirrors so that would be easy... thanks
