H22A
By Stank.EG6.Stay.Nasty
#286776
EG6b20R wrote:
Stank.EG6.Stay.Nasty wrote:look at the bisimoto website... he might have some good ish for the H
I know i was considering that, but he does nOT post or even give the cam specs on his site.. Like the Lift at durations for the the primary and secondary and VTEC lobes..
you can ask them directly.. thats what i did when i was looking into the D16 cams
By RWMIII
#286827 I have a very close friend with Skunk2s. Power curve is excellent. On stage II's if i remember correctly the numbers were 184hp 144 ft-lbs. Full valvetrain upgraded, along with Type S pistons, i/h/e were the only supporting mods.
#286881
RWMIII wrote:I have a very close friend with Skunk2s. Power curve is excellent. On stage II's if i remember correctly the numbers were 184hp 144 ft-lbs. Full valvetrain upgraded, along with Type S pistons, i/h/e were the only supporting mods.
not too shabby
By Fada Blayne
#286885
not too shabby
those numbers are wack for a H motor. those numbers can be easily achieved by a relatively stock motor with I/H/E and a tune.
By bks84
#286886
not too shabby
Kinda what I was thinking...
http://www.preludeonline.com/f93/dyno-r ... ms-249276/
#286899
not too shabby
the lowest output from a h-series is 182 hp... maybe he's talking about a SOHC :?
By Eg6H2D
#287298
not too shabby
Sickk!! 215whp.. not bad that 177tq must be fun!!
By Eg6H2D
#287300 So i guess Skunk2 Pro2s it is . ill have the head ported and what not so might as well spend the extra money on good ish!
:thumb:
By bks84
#287327 Just make sure you get the right springs to go with them.
#287356
bks84 wrote:Just make sure you get the right springs to go with them.
werd!
By mooze
#287388
EG6b20R wrote:So i guess Skunk2 Pro2s it is . ill have the head ported and what not so might as well spend the extra money on good ish!
:thumb:
you can always swing the extra money my way
By Eg6H2D
#287566
:thumb:
LMAo! and get what.. Actually what do you have for sale that will be useful to me? PM me.. a list.. =]
:thumb:
By Eg6H2D
#287567
Of course.. ill be going with Supertech.. With Chromoly Steel Retainers..
#287570
yessir!!!
By bks84
#287585
Supertech makes 2 different springs (with different specs), again pick the right ones.
If I'm not mistaken you'd want these SPR-H1000D. Otherwise you may end up with all the same trouble the All Motor B series guys are having. Flat cams, chewed up rockers.
