H22A
By kross
#266434 i am in the process of swaping an h22a4 from a crashed hatch to new hatch and was just swaping over the extra vtec wiring and im guessing o2 sensor wire. and i was a dumbass and didnt remember where the pins exactly came out of the ecu. there was 3 wires, and each was in one of the three plugs (A, B, and D) everywhere i read about wiring in vtec doesnt have a wire in each plug so im wondering whats going on. is one for an o2 sensor for the h22 or idk, im lost haha. any help would be appreciated as im trying to get this motor going by the weekend
By RWMIII
#266455
Connector A
1. INJ4 - yellow
2. INJ3 - blue
3. INJ2 - red
4. INJ1 - brown
5. Secondary O2 Heater - orange/blue
6. Primary O2 Heater - black/white
7. EGR solenoid - orange
8. VTS (VTEC solenoid) - green/yellow
9. LG1 (ground) - brown/black
10. PG1 (ground) - black
11. IGP1 (ground) - yellow/black
12. IACV (idle air control valve) - black/blue
13. EMPTY
14. EMPTY
15. EVAP purge control - red/yellow
16. Fuel Pump Relay - green/orange
17. ACC (A/C control) - pink/blue
18. MIL - gray/red
19. Alt Control - white/green
20. ICM - yellow/green
21. EMPTY
22. LG2 (ground) - brown/black
23. PG2 (ground) - black
24. IGP2 (ground) - yellow/black
25. ICSOL (Intake Control Solenoid) - white
26. IAB (Intake Air Bypass) - red/blue
27. Radiator Fan Control - green
28. 2WBS (Evap bypass) - green/white
29. VSV (Evap Canister) - orange/green
Connector C
1. EMPTY
2. CKP P - blue
3. TDC P - green
4. CYP P - yellow
5. AC switch - blue/orange
6. Starter Signal (STS) - blue/red
7. Service Check Signal - red/white
8. K-line - light green
9. A/T related
10. Voltage Backup (VBU) - white/yellow
11. EMPTY
12. CKP M - white
13. TDC M - red
14. CYP M - black
15. Vtec Pressure Switch - blue/black
16. Power Steering Switch - green
17. Alt FR signal - white/green
18. Vehicle Speed Sensor (VSS) - blue/white
19. A/T related
20. Purge Flow Switch (PFSW) - brown
21. EMPTY
22. Immobilizer code - brown/yellow
23. EMPTY
24. EMPTY
25. EMPTY
26. A/T related
27. A/T related
28. A/T related
29. A/T related
30. A/T related
Connector D
1. TPS (Throttle Position Sensor) - red/black
2. ECT (Engine Coolant Temperature) - red/white
3. MAP (Manifold Absolute Pressure) - red/green
4. VCC1 (MAP voltage) - yellow/red
5. Brake switch - white/black
6. KS (Knock Sensor) - red/blue
7. Primary O2 sensor - whtie
8. IAT (Intake Air Temperature) - red/yellow
9. EGRL (Lift) - white/black
10. VCC2 (TPS Voltage) - yellow/blue
11. SG2 (ground) - green/black
12. SG1 (ground) - green/white
13. EMPTY
14. Secondary O2 Sensor - white/red
15. Fuel Tank Pressure - white/blue
16. ELD (Electronic Load Detector) - green/red
http://bbmoto.net/wiki/index.php?title=Ecu_Wiring_Table
By kross
#266461 another question, i got the car with the h22 already swapped in, and i dont know if it has a resistor pack in it, i looked over all the wiring and didnt see anything but then i was thinking he put injectors that didnt need the resistor pack (peak n' hold or saterated?)
By jigga36
#266816 the h22a4 does not need the resistor pack for the injectors
