Hasport shift linkage
Thu Mar 29, 2012 12:49 am
by jayEGR
so i was looking into this because i have alot of play in my shift linkage and wanted to ask you guys your opinion on the product i also i have a short shifter that i got from my friend so i need a need shift linkage asap, is it worth it?
http://www.ebay.com/itm/Hasport-92-00-C ... 470wt_1037
Thu Mar 29, 2012 1:17 am
by dbrooks
From what I hear, they're pretty legit. I know they make an adjustable one though, just in case that one doesn't work.
Thu Mar 29, 2012 1:45 am
by blk92hb
have you tried replacing the bushings???
Thu Mar 29, 2012 3:21 am
by TrailerTrash
blk92hb wrote:have you tried replacing the bushings???
the bushings arent going to fix the slop in the linkage
Thu Mar 29, 2012 4:59 am
by Gustavo
They r amazing. Bought it 4 my hatch i reccomend u buying Energy Suspension shifter bushings along with the shift linkages. Trust me it's a good combo u won't b dissappointed.
Thu Mar 29, 2012 12:59 pm
by blk92hb
Ok I'm not understanding how the shift linkages can make a shifter feel sloppy. They don't do anything but hold the shifter, connect to the transmission to switch gears. The only thing I would think that will make it feel like slop is the bushings holding the linkages up and the bushings that hold the shifter its self.
Thu Mar 29, 2012 7:50 pm
by Eg6H2D
blk92hb wrote:Ok I'm not understanding how the shift linkages can make a shifter feel sloppy. They don't do anything but hold the shifter, connect to the transmission to switch gears. The only thing I would think that will make it feel like slop is the bushings holding the linkages up and the bushings that hold the shifter its self.
I agree any slop like side to side or any thing like when it doesnt feel firm are the bushings them selves along with the bushing at the bottom of the actaul shifter itself. Getting new linkages do not make your shifter Stiffer. the bushings do!!!
Also your better off getting the OEM Integra ITR shift linkages anyway from Honda. ive heard of the innnovative and Hasporrt units snapping from time to time due to hard shifts and slamming gears .
http://www.ebay.com/itm/TORQUE-SOLUTION ... fb&vxp=mtr
Get a quality shifter and youll be happy..
Re: Hasport shift linkage
Thu Mar 29, 2012 7:54 pm
by Eg6H2D
jayEGR wrote:so i was looking into this because i have alot of play in my shift linkage and wanted to ask you guys your opinion on the product i also i have a short shifter that i got from my friend so i need a need shift linkage asap, is it worth it?
But definately for $139 that's a steal..
Fri Mar 30, 2012 3:36 am
by TrailerTrash
Fri Mar 30, 2012 4:03 am
by Hatch-O-Doom
Whats the bushing called right under the shifter? Mine is all torn apart...
I have BWR bushings for the front like in that link, but I am talkin round one where shifter sits?
Sat Mar 31, 2012 1:08 am
by jayEGR
im have to look into it more but those bushing are better then 137 but the price is good like you said, i might look at 20 bucks vs 137 , but will see if i get this or not
