- Sun Feb 05, 2012 5:21 pm
#293409
i just put a turbo set up on my ls vtec and it runs like i have crazy race cams, almost like therz a pause in ignition after every rotation. this all happens with the MAP sensor out because it will not run with it plugged in? with the MAP plugged in you have to play with the throttle to keep it running and when you open the throttle it dies but as the throttle body closes the revs increase. so im like wtf mait
anyways wondering if any of you have had similar problems or know of anyway to make the car run so i can get it to the tune shop. ohhh and btw i had the tune shop put a base map on my ecu first so im wondering if that might be the problem as well. any help or knowledge helps thanx.
