- Thu Mar 01, 2012 6:23 am
#296685
your going to need injectors and a fuel pump. i would change the filter too and inspect the lines.
for turbo setup you need a turbo , exhaust mani, wastegate, blow off valve, turbo lines coolant/oil, downpipe, fmic and piping, map sensor if you plan more than 10psi, tunable ecu, and a tuner. plus you have to install it.
other things might pop up during the build like clutch, gaskets and seals. i would change the vac lines too if they are old. and other maintance
sometimes you have to remove a/c and get a smaller radiator. some exhaust manis say with or without powersteering watch out for that.
thats pretty much it. you could also get a boost gauge and wideband sensor to watch over the motor.
some people need spark plugs too.
i would also look over entire suspension and brake setup before your plan to go fast.
good luck and stay safe
1995 4 door civic b18c jrsc
