- Fri Sep 02, 2011 4:49 am
#270057
kross wrote:i have a few questions about your manifold, firstly why are you going with the side angle mount? dont you want shorter primaries so it spools up quicker? and also doesnt the sharp 90 coming out of the block mess with the exhaust flow? haha dont wanna sound like i know anything just curious. its definitly a original design ive never seen before
1.Sidewinder because it allows me to keep a/c even with the h2d setup and have long runners....i don't need ridiculous quick spool with a h... torque+extra quick spool=0 traction.a longer runner manifold will have better flow up top, while a shorter manifold can yield a faster spool, with also less transient lag. since im running a garrett gt28rs lag is a very small issue
2. No if you look closely you can see all four runners meet at a central point...reason being....they are equal length... The idea being that the exhaust pulses will be spaced out evenly and arriving at the turbine wheel on the turbo at there own time in the firing order. If they arrive sooner or later, they may interfere with the exhaust pulses from the next firing cylinder.
this is a professionally engineered manifold by LOVEfAB....not just something i tried to piece together....
