| View previous topic :: View next topic |
| Author |
Message |
EJ1STYLEN
EG Regular
Posts: 114 Feedback Score: 0
Posted: Sun Sep 05, 2010 3:26 am Post subject: annoying srs light on... |
| Hey guys i just replaced me steering wheel and now i need to get rid of the freaking srs light off...is there a how to? Or can i just unplug the srs plug under the dash were the underdash fuse box is at?.... |
| Back to top |
Classiccarsrule85
do not want punctuation
Posts: 2926 Feedback Score: 3
1995 Honda Civic cx
Posted: Sun Sep 05, 2010 3:33 am Post subject: |
depending on what year your car is what id do is unplug both your d.side and p.side (if equipped airbag just in case) and pull the yellow plug on the back of the cluster as this would be the easiest way to get rid of that light.... _________________
1995 Civic CX-project sold
1992 civic cx -New project
not using punctuation or good sentence structure since day 1 |
| Back to top |
EJ1STYLEN
EG Regular
Posted: Sun Sep 05, 2010 3:55 am Post subject: |
| Anybody have a diagram of which plug to pull off... |
| Back to top |
Classiccarsrule85
1995 Honda Civic cx
Posted: Sun Sep 05, 2010 4:17 am Post subject: |
its easy theres only one yellow plug on the cluster (thats for srs) then once thats unplugged you will have no more annoying srs light on your cluster.... _________________
| Back to top |
EJ1STYLEN
EG Regular
Posted: Sun Sep 05, 2010 6:47 am Post subject: |
| Okay...but is that yellow plug behind the cluster goes down the underdash fuse box were theres a yellow plug? |
| Back to top |
Classiccarsrule85
1995 Honda Civic cx
Posted: Sun Sep 05, 2010 3:24 pm Post subject: |
| EJ1STYLEN wrote: | | Okay...but is that yellow plug behind the cluster goes down the underdash fuse box were theres a yellow plug? |
i never traced it but i highly doubt it as the yellow plug is tied into the the cluster dash harness which besides that yellow plug on the back of the cluster there really isnt any other yellow plug on that harness... _________________
| Back to top |
{ikon}EM1
EG Groupie
Posts: 638 Feedback Score: 0
Posted: Sun Sep 05, 2010 4:02 pm Post subject: |
Just take out the cluster and pull the yellow wire or pop out the light buld...  _________________ i pitty the foo who aint got vtec...... |
| Back to top |
EJ1STYLEN
EG Regular
Posted: Mon Sep 06, 2010 12:17 am Post subject: |
| I tried taking out the cluster but the black bezel is so hard to come off i took out the 2 screw holding it and the hazars button...i was afraid to yank it off that i might brake the vent or whatever.... |
| Back to top |
ikon
i have two right feet
Posts: 718 Feedback Score: 0
1993 Honda Civic Si
Posted: Mon Sep 06, 2010 2:58 am Post subject: |
its not the one inder the dash. mine is unplugged and i have a light. just undo the one behind the bezel or do the bulb. as long as ur careful and gentle it will come out. _________________ single slammer = one cam of fury.
si = supercharger inside |
| Back to top |
{ikon}EM1
EG Groupie
Posted: Mon Sep 06, 2010 4:02 am Post subject: |
| ikon wrote: | | as long as ur careful and gentle it will come out. |
^^^Yea just be gentle with it like a new born porkypine....  _________________ i pitty the foo who aint got vtec...... |
| Back to top |
EJ1STYLEN
EG Regular
Posted: Mon Sep 06, 2010 5:26 am Post subject: |
| Alright koo...ill be gentle with it...lol ill try to take it off tomorrow |
| Back to top |
suspendedHatch
Knows Hondas
Posts: 1299 Feedback Score: 0
1992 Honda Civic vx
Posted: Mon Sep 06, 2010 4:45 pm Post subject: |
There is a screw behind the clock blank. You're going to need a panel remover tool also.
I'm with you man. Leave the cluster alone if you haven't pulled it before you're going to break stuff. On the floor behind your radio is the SRS computer. Unplug that. Then unplug the yellow connector at the fuse box and remove the SRS fuse. If you want to totally remove the airbag setup, then there are sensors under the firewall mat on each side.
It's not true that the SRS harness is integrated into the dash harness. You can completely gut the SRS wiring, ECU, airbag, and sensors and save some weight. The only thing is that the horn wire and airbag trigger wire are together on the steering column. However, if you have an aftermarket steering wheel, you've taken care of this already.
If you want to remove that SRS module from the back of the cluster, just be aware that this leaves a noticeable hole in the cluster. The easiest thing to do is to cover the SRS light slot with a piece of black tape. _________________
| Back to top |
asianrob
Changes his name more than his avatar
Posts: 3372 Feedback Score: 2
1992 Honda Civic
Posted: Mon Sep 06, 2010 4:57 pm Post subject: |
check the SRS code. see what it is? maybe you just need to reset the SRS light? _________________ 92 civic cx sold!!
horizon gray 94 LX-A (WRECKED 10-31-06 RIP)
white 92 civic Si (traded)
primered 94 teg sold
92 civic DX
92 civic LX |
| Back to top |
Classiccarsrule85
1995 Honda Civic cx
Posted: Mon Sep 06, 2010 5:08 pm Post subject: |
| suspendedHatch wrote: | There is a screw behind the clock blank. You're going to need a panel remover tool also.
If you want to remove that SRS module from the back of the cluster, just be aware that this leaves a noticeable hole in the cluster. The easiest thing to do is to cover the SRS light slot with a piece of black tape. |
There is no screw behind the clock blank as thats screwed in so you wouldnt be able to remove it theres two on top where the cluster is and one behind teh hazard switch.....
to take it out pop the p.side off first and then d.side and make sure the vant on the d.side is closed idk why but when its open seems to me that its harder and more apt to break....
and also yes you can cut the plugs off but im pretty sure the srs light plugis in teh harness as you cant simply take the three wires out as there is no seperate plug theres a main srs harness linked to the srs ecu that you can take out but there are still some plugs integrated into things that unless you tore everything out you wouldnt be able to get out easily.... _________________
| Back to top |
