| View previous topic :: View next topic |
| Author |
Message |
teal_dx
The Legend
Posts: 10168 Feedback Score: 9
1992 Honda Civic
Posted: Fri Sep 29, 2006 1:20 pm Post subject: How to wire a Resistor Box for low impedence injectors |
When you are piecing together a turbo kit to save money, it's hard to drop a few hundred on some RC injectors. DSM 450cc's can be bought for about $50. However, you will need a resistor box to run them. A resistor box can be found for about $10. The resistor box will make the injectors the correct impedence to use with your ECU.
Here's a diagram I made:
| Back to top |
da90_2
Poster
Posts: 69 Feedback Score: 0
Posted: Mon Oct 09, 2006 11:08 pm Post subject: |
| so then you just hook up the unstriped wires to the corresponding wire |
| Back to top |
teal_dx
The Legend
1992 Honda Civic
Posted: Tue Oct 10, 2006 12:22 am Post subject: |
| yep, exactly |
| Back to top |
eghatch
Poster
Posts: 33 Feedback Score: 0
Posted: Thu Oct 12, 2006 12:32 am Post subject: |
Posted: Fri Sep 29, 2006 1:20 pm Post subject: How to wire a Resistor Box for bigger injectors
sorry i mean no disrespect.. i just dont really like the way the topic is worded... maybe call it: How to wire a Resistor Box for Peak & Hold Injectors or (low impedence injectors)
cuz bigger injectors are NOT always peak and hold.. they make up to 750cc injectors that are still saturated(and do NOT need a resistor box)
I KNOW THAT YOU KNOW THIS ALREADY.. Just probably dont want to confuse anyone who doesnt know..
just a thought..
good luck with the site!!  |
| Back to top |
teal_dx
The Legend
1992 Honda Civic
Posted: Thu Oct 12, 2006 1:27 am Post subject: |
thats a good point, I should say that when using the common DSM 450cc's you will need to do this. You can get the DSM's for about $50 If you bought a set of RC's (high impedence) for a few hundred bucks, you will not have to worry about this at all - just plug them in and go.
Thanks for adding and hopefully clearing this up for someone who didn't know  |
| Back to top |
eghatch
Poster
Posted: Sat Oct 14, 2006 9:25 pm Post subject: |
here is a little something i made to help out. this is my 93 cx hatch with a b16 swap.
then put your power source wire and sensor pins back in and you should be good to go!! |
| Back to top |
teal_dx
The Legend
1992 Honda Civic
Posted: Wed Dec 20, 2006 8:34 pm Post subject: |
here is another diagram I came across that may help:
 _________________ Do Not PM me your technical questions. Post them in the forum!
My 1992 SOHC Turbo Hatch Build Thread |
| Back to top |
teal_dx
The Legend
1992 Honda Civic
Posted: Mon Sep 24, 2007 5:09 pm Post subject: |
Saturated Injectors (no resistor box needed to run on an EG):
1997-up Prelude VTEC
1992-95 Civic Si/EX
1996-00 Civic
1992-00 Integra LS/GSR/ITR
Peak & Hold Injectors:
1988-91 Civic/Crx Si/HF
1990-91 Integra
1992-96 Prelude non-VTEC
1992-96 Prelude VTEC
1g DSM Non-Turbo 4g63 240cc
2g DSM Non-Turbo Uknown if works
1g DSM Turbo Automatic 380cc
1g/2g DSM Turbo Manual 450cc
(Blue tops are 1g DSM injectors, and black tops are 2g DSM injectors) _________________ Do Not PM me your technical questions. Post them in the forum!
| Back to top |
