- Mon Nov 05, 2018 12:53 pm
#6908820
Good day everyone. It has been a good minute since I have been on here. Life has been on the move.
Need to ask for your help.
Driving home the other day car just shut off.
Pull over and tried to start it but it wouldn't start.
Got it home on the tow , started to examine what is wrong. 95 hatch with a 96 GSR obd1 with a chipped p72 , 95 SI wire harness is the power plant.
I have checked for codes and got a Bad IACV , replaced. Replaced TPS , replaced Map sensor , changed coolant and bled thes system. I run NO thermostat. Checked the plugs , the are wet from fuel. Running rich. I replaced all injectors. Fuel pressure reg is AEM aftermarket. I have a gauge on it . 40 - 45 pounds on the dial.
I have a stock p72 that I swapped in to check and it does the same but giving a code of O2 sensor. No worries on that.
The car will start , but surging idle and running rich. I am lost at the moment. I have checked for any vacuum leaks , none that I can see.
I can take a vid of the car tonight to show we're i am.
Drive it HARD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?t=28277
