purge vavle and iavc mix up
ECU, Wiring, Sensors
Postby madhatchride » Fri Apr 12, 2013 4:07 pm
ok so i made the mistake of plugging the purge valve side to the iavc and vice versa.i called a shop and they said if this happend that it would burn something out in the ecu. well what would this effect does anyone know what would happen? the car isnt 100 % done so i have nothing to go by on if it runs better or worse
bomb green hatch club
madhatchride
EG Regular
Postby rustyrex » Sat Apr 13, 2013 1:35 am
the only thing that will happen is the idle will jump up and down real fast like the vacuum line for the brake master cylinder is unpluged. i did this exact same thing when i did my swap, those 2 harness plugs are exactly alike. just make sure you switch them before you go to drive it.
rustyrex
EG Groupie
EG Groupie
Postby madhatchride » Mon Apr 15, 2013 2:53 pm
well see the problem is i didnt know i didnt catch they were switched till a a month after ive been testing it and driving it a lil will it cause any problems other wise like for example the car will not hit red line at all n doesnt seem to run like a b18 should
madhatchride
EG Regular
Postby rustyrex » Mon Apr 15, 2013 4:31 pm
Of course it is not going to run correctly. The iac and purge valve are not working. It take 10 seconds to swap plugs. I'm really surprised its driveable. My cars idle was jumping so bad when I did that it kept stalling when I tried to pull out of my driveway.
rustyrex
EG Groupie
EG Groupie
Postby madhatchride » Tue Apr 16, 2013 3:24 am
well even after i switched them i still have the slight retarded jump issue and they said it would burn a big hole in my ecu
madhatchride
EG Regular
Postby madhatchride » Tue Apr 16, 2013 3:25 am
not a big hole but would burn the main board
madhatchride
EG Regular
Postby TrailerTrash » Tue Apr 16, 2013 3:38 am
:eh:
hook them both up and start the car. if the car runs like shit and the check engine light is on then they are backwards.
TrailerTrash
Sr. Member
Sr. Member
Postby madhatchride » Tue Apr 16, 2013 3:44 am
i know there right now im sure it idles ok and i have no cel for my iavc but i was told that having them switched for a period of time can burn your ecu out and btw i just got done reading your whole coupe build forum :) nice
madhatchride
EG Regular
Postby JUICE » Tue Apr 16, 2013 4:44 am
I'd say its probably fine, people confuse them all the time and have no problems once they fix it. I'm actually running my EBC boost solenoid off the wires that used to go to the purge valve.
JUICE
Civic-EG Golden Post Whore
Return to Chassis - Electrical
Who is online
Users browsing this forum: No registered users and 1 guest
