B16, B18, B20
By motoxash
#358872 I have a b16 with msd blaster coil pack fitted randomly car won't start been haveing intermittent start problem one the last month change the cap leads ignition module and main relay one of these fixed the problem for a week now the car is back to bad starting again and failing to start
#358878 How is it not starting? Is it even cranking? or just clicking? Is the fuel pump priming? Are you getting spark or compression? I agree with Driv-it-hard, those MSD caps/external coils are known for causing problems compared to the OEM ignition.
By Driv-it-hard
#358882
teal_dx wrote:How is it not starting? Is it even cranking? or just clicking? Is the fuel pump priming? Are you getting spark or compression? I agree with Driv-it-hard, those MSD caps/external coils are known for causing problems compared to the OEM ignition.
That is so true for those MSD cap /coil adding headache to perfect motor.
