- Wed Jan 28, 2015 12:11 am
#351350
Hey all
Ive pretty much finished this swap . All i need is a tps sensor and speedo sensor so im gunna have a check engine light .
So, i have the front end of the car on jacks . I started the car sounds good and revs went to2500. I expected the high revs cuz i dont have a tps bolted on. The issue is. When im in neutral and i slowly let go of the clutch in neutral i hear a rubbing noise. That im assuming is the clutch and fly rubbing. I let go of the clucth even more then therevs drops to 1500. Is it normal that the revs drop that much ? Also its a 9 lb flywheel and stage two exedy clutch. One more thing. What t bracket exactly do i need for this swap? From what car? I hear i need one from a del sol v tec model ?
