- Thu Oct 02, 2014 10:03 pm
#348958
Hi there,
I just recently bought an EG with a b16a2 swap nearly done... Anyways just finishing off the job but this is my first civic so still learning the nuances.
I was wondering if anyone could tell me. The two front lower engine mounts. The m12x1.25 threaded shaft that goes through the rubber bushes. Is this meant to be a very loose fit. I didn't measure the ID of mount hole but is probably more like 14mm +.
So my question is this meant to be a loose fit then it relies on the clamp from the washer and nut to keep in place or do i have the wrong rubber mounts!
Have done lots of searching and couldn't find anything. An answer would be much appreciated.
Cheers
Ed
Cheers
Ed
