B16, B18, B20
By madhatchride
#346584 so i purchased a brand new harness for my gsr swap into my eg civic.i supposable got a 94 intega gsr harness. it is not cut but the only wiring diagram that was put on this site was a 92 civic harness and when i match it to mine it isnt the same colors. it should be a plug and play deal but i seem to think i got a ls harness instead of a gsr like i was suppose to. which will still work but i need a diagram because were the gsr intake is made diffirent some of my plugs dont reach and i need to know which goes to which such as how the tps and map sensor are identical and beside each other on the harness.so i need a diagram to make sure i am extending the correct ones.
By HeikDiesel
#346588 Every car I've had a B series swap in I used the d series civic harness for those very reasons
