B16, B18, B20
By Datsmart
#341269
BUT I COULD JUMP START THE CAR
Did you jump the car with battery cables or Bump start the car by rolling or pushing it?
If the starter will not turn, check the wiring at the starter first.
By egsedanguy
#341312 check all fuses, grounds and wires. make sure everything is plugged in. could be a bad batteri. it may not have the crank amps for your new b engine. few things i wo9uld check. :thumb:
