B16, B18, B20
By Squirrelman91
#333281 Ok so I just rebuilt my motor and I drove it around the block and first time around it does fine but when the motor starts to get warm I loose all power and starts to bogg down really bad what would cause this [/list]
By bks84
#333337 What have you checked?
By Squirrelman91
#333348 I've checked the map sensor the o2 sensor.will the b18 run on the stock eg computer?.and how do I tell what computer I have?
By nd1983
#333359
Squirrelman91 wrote:I've checked the map sensor the o2 sensor.will the b18 run on the stock eg computer?.and how do I tell what computer I have?
the b18 needs the b18 computer to run properly. alot ofstuff willl be off, A/F, o2 readings, all the engine components.
By Squirrelman91
#333375 How do I tell if I have the eg computer or the b18 computer I bought the car with the b18 already swapped so I dont know which one I have
By Fada Blayne
#333377 You need a pr4 ecu. Take a look at the ecu you have at the moment and make sure that it is one. You can also run a p75 with a 0db2 to Obd1 convertor harness.
By bks84
#333395 p75's came obd1 as well. 94-95 integra rs/ls/gs/"se" whatever trim as long as it has a b18b1 in it.
if your car has the correct ecu pr4 or p75, doesnt matter, then id check calibration on TPS and test coil/ignitor (or if you have a buddy who has a good LS distributor just swap the distributors)
any check engine lights?
By Squirrelman91
#333397 Ive replaced the coil and ingitor. I know its not the dizzy my friend thinks its the ecu
By nd1983
#333400
Squirrelman91 wrote:my friend thinks its the ecu
and his reason? most just don't die.
By Squirrelman91
#333401 So I just pulled the ecu out and I have the stock 94 PO6. so what do I do??
By Fada Blayne
#333409 You should obviously swap it for one of the ones mentioned above. Should be a relatively easy find at a junkyard or even craigslist. :thumb:
By Squirrelman91
#333414 My motor is obd2 will the p75 with the convertor work??
By Squirrelman91
#333415 My motor is obd2 will the p75 with the convertor work??
By bks84
#333423 doesnt matter what OBD your engine is, if its in a 92-95 Civic, then its being ran as OBD1, since they came OBD1.
Have you checked to see what ECU youre currently running? If not, do that. If youre on the wrong ECU it probably wont run well and could be the root of all the bogging, and whatever other problems youre having.
