- Tue Sep 10, 2013 11:35 am
#336507
They're both high impedance.
JUICE wrote:They're both high impedance.
Ok thanks
Gunni wrote:http://ww2.justanswer.com/uploads/thebesthonda/2009-12-03_194407_vtec_solenoid.png
JUICE wrote:^sorry, that was more a statement in relation to his issue where it wouldn't matter running obd2 injectors with obd1 harness/ecu however they're plugged in as they're both saturated 240's
PirateEG wrote:any update?
might also be a good idea to check the ground on the VPS. Do know know why it would be working but not in 4th or 5th... or why a stock ECU would kick in VTEC at 4500RPM...
PirateEG wrote:VTEC will only come on at proper oil pressure, at speed and proper temp...
Have you checked for fuel pressure at the fuel filter?
I know when I got my poorly swapped B16a2 the fuel filter was JUNK and fuel barely came out. Just loosen the top screw (COLD ENGINE) and see how well it comes out.
For peace of mind too, not a bad idea to make sure you have a radiator full of coolant and coolant in the reservoir.
PirateEG wrote:I wouldn't imagine a "stock" fuel filter giving you any sort of issue. a new filter will flow well enough to support the fuel needs of a motor with just bolt-ons.
as for your oil pressure concerns
http://www.youtube.com/watch?v=8f2fcbTh5yw
^ in short, wouldn't be your oil pump.
Could be the solenoid, have you cleaned that filter?
How fresh is the oil/have enough oil?
Another option, for shits n giggles. Take out the FPR... you never know.
OR a couple more PSI of pressure.
on a side note. I feel ya man, bought a swapped car from moron swapper. IAT was plugged into the IACV, no IAT, VTEC was not wired to ecu but a push pull switch on the shifter , and the valve lash was off by .006".
I have noticed that some times it is best to stick with what Honda did to get things back to base... ie your FPR.
just found this too about solenoid gasket replacement
http://www.youtube.com/watch?v=GfwNvotd ... e&t=21m05s
you get a new screen with the gasket...
