- Wed May 22, 2013 2:14 am
#332010
http://www.youtube.com/watch?v=8iy2Dtaz ... e=youtu.be
chipped p72 ecu ***p28 not 72... p72 is the head my bad
b18c maybe b18c1 (block says b18c, but when i opened her up I noticed C1 pistons (A0)
It did not do this before the HG change...
No engine light. Car seems to be running fine, although I don't think vtec is kicking in.
So i did notice the vtec pressure switch was hanging on 1 thread of wire, so I fixed that. To check my fix I took out the switch and it threw a code, then put the switch back and no codes.
I did change the oil after the HG fix. (I am using fram tough guard oil filter, never had a problem with it before... although it is bigger then OEM)
I'm not sure how the B18c checks the oil pressure, but there is nothing attached to the oil pressure switch, and never was from the day I got it (swapped).
Anyone know what's going on?
