- Sat Mar 16, 2013 4:51 pm
#328726
Is this everything I need for changing a new head-gasket? The engine is jdm b18c, but I heard [the head gaskets] are all the same. Is .030 thickness stock, couldn't find a lot of info, and on wiki it said the stock bore was 81mm, so maybe thats correct.
Head gasket (cometic 81mm bore .030 thick): http://tinyurl.com/cqb6slv
Arp studs - Have (22ft lbs 62 80, right?)
ARP lube(can I/should I use this on cap bolts too?): http://tinyurl.com/bryp5ke
HondaBond(I was told I need this to seal the cams, is there anywhere else I should put this) : http://tinyurl.com/byjzk5t
(I know the bolting patterns for installing and removing the bolts, and the torque specs for everything, im using http://www.clubintegra.com/board/showthread.php?t=69825 and http://www.civic-eg.com/viewtopic.php?t=14336 as a guide). The water pump and timing belt was replaced less then 5k miles ago. I will check for warpage with a straight edge and feeler gauge.
ANY HELP IS APPREICIATED :]
