- Thu Jan 03, 2013 6:07 pm
#323224
i just swapped my hatch with a 94 gsr motor . its throwing i believe code 5 which is map sensor . how do i go about checking mines ? when i jump the wire to read the code it blinks once with a pause then blinks 5 times then starts over . so im guessing o2 sensor and map sensor code ???
- Thu Jan 03, 2013 7:50 pm
#323225
Are the 5 blinks fast or slow?
- Thu Jan 03, 2013 9:11 pm
#323229
Since you get one blink and then 5 after that it sounds more like code 15 to me which is ignition output signal
1992 Honda Civic SIR-S
- Thu Jan 03, 2013 9:23 pm
#323232
its a slow blink pause then blink blink blink blink blink . my car starts and drives but shuts off on me and dies and does not want to start sometimes .; would that ignition code 15 do that . and how will i go about fixing that problem ?
- Thu Jan 03, 2013 11:11 pm
#323244
http://www.azht.net/forum/showthread.php?t=79309
A lot of sites are blocked because I'm at work but just google OBD1 Code 15. 4689736483 results came up
- Sun Jan 06, 2013 2:34 am
#323386
yea, code 15 is something to do with output in the distributor. id first check the wires at the distributor plug, then if they're good I'd try a new/known good distributor.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
