- Thu Oct 11, 2012 3:16 pm
#317737
Hey guys, I have
JDM B16 head
AUDM B18C2 block (oem crank and rods)
PR3 pistons with 1mm shaved off the top
Skunk2 Stage 1 cams
With the 1mm shaved off the PR3 pistons i'm hoping to get a similar compression ratio to a jdm ITR. I will be using the stock oem cam gears, so I won't be dialing it in. What would my compression be with this combo? Do you think I need to clay my motor? Any input I much appreciate it
JDM B16 head
Skunk2 Stage 1 cams
