obd1 from obd2
Tue Sep 18, 2012 10:35 pm
by madhatchride
ok so im currently swapping the blew motor out of my 92 hatch that is a b18b1 and putting a b18b1 back in it but the parts car i have is a obd2 car and the intakes are diffirent. will i be a be able to just swap motors with the same intakes or will i have to pull the one off the blew motor to put on the new engine
Tue Sep 18, 2012 11:49 pm
by FG2_Andrew
Probably easier to just pull it..
Wed Sep 19, 2012 2:42 pm
by d-mon
yes, use the intake manifold with the obd1 sensors.
Wed Sep 19, 2012 6:06 pm
by madhatchride
how hard is it to do ? and will i be able to use my old gasket cause i just priced one and it was 48 bucks n thats no bueno for me right now
Wed Sep 19, 2012 6:54 pm
by d-mon
you definitely want a new i/m gasket. vacuum leaks suck big time.
Wed Sep 19, 2012 6:55 pm
by madhatchride
is it gonna be pretty easy to swap over ive got this far without much trouble at all
Wed Sep 19, 2012 9:16 pm
by d-mon
just the nuts on the under side and the angled bracket are the hardest parts.
and don't mix up your map and iacv.
Fri Sep 21, 2012 1:06 am
by bks84
What gasket are you pricing at $48? Pretty sure they're under $10 at the parts store.
Fri Sep 21, 2012 2:00 am
by madhatchride
intake gasket i priced it through cq were my sisters works
Fri Sep 21, 2012 2:03 am
by bks84
CQ = carquest?
I checked at Autozone, Advance and Orielly... all three under $12.00
Fri Sep 21, 2012 9:48 am
by asianrob
you can get a hondata gasket for bout 30$ IIRC
Sun Sep 23, 2012 6:37 pm
by madhatchride
ok so i guess my sister mis understood what i want n i shoulda listened cause i used my old gasket n i ended up with a massive antifreeze leak so now im have to pull it back off but other then that my swap was a success and started first turn of the key
my first swap to
