B16, B18, B20
By madhatchride
#315969 ok so im currently swapping the blew motor out of my 92 hatch that is a b18b1 and putting a b18b1 back in it but the parts car i have is a obd2 car and the intakes are diffirent. will i be a be able to just swap motors with the same intakes or will i have to pull the one off the blew motor to put on the new engine
By FG2_Andrew
#315974 Probably easier to just pull it..
By d-mon
#316023 yes, use the intake manifold with the obd1 sensors.
By madhatchride
#316033 how hard is it to do ? and will i be able to use my old gasket cause i just priced one and it was 48 bucks n thats no bueno for me right now
By d-mon
#316035 you definitely want a new i/m gasket. vacuum leaks suck big time.
By madhatchride
#316036 is it gonna be pretty easy to swap over ive got this far without much trouble at all
By d-mon
#316058 just the nuts on the under side and the angled bracket are the hardest parts.
and don't mix up your map and iacv.
By bks84
#316125 What gasket are you pricing at $48? Pretty sure they're under $10 at the parts store.
By madhatchride
#316133 intake gasket i priced it through cq were my sisters works
By bks84
#316134 CQ = carquest?
I checked at Autozone, Advance and Orielly... all three under $12.00
By asianrob
#316162 you can get a hondata gasket for bout 30$ IIRC
By madhatchride
#316277 ok so i guess my sister mis understood what i want n i shoulda listened cause i used my old gasket n i ended up with a massive antifreeze leak so now im have to pull it back off but other then that my swap was a success and started first turn of the key :) my first swap to
