B16, B18, B20
By klabbott
#314246 im pretty new at honda's and i jut picked up a 92 Si hatch with a LS Vtec swapped in.. the car runs great, and hits vtec great, but at times when i down shift quick or rev high , the car cuts out and will not rev past 3500..
im just woundering if anyone else had the same problem or know what could be causing this.
By klabbott
#314299 my CEL is on, but i have no idea how to read the codes.. or what the connector looks like as it is an obd1.
and i dont have any problems with the speedo.
By klabbott
#314332 checked codes and got
16 - Fuel injectors
22 - VTEC pressure valve
41 - Primary oxygen sensor heater
By klabbott
#351906 for anyone that wants to know, it was the Vtec pressure sensor that was causing my car to go into limp mode and not go above 3500. chipped the ecu and disabled the vtec pressure sensor and it worked perfect.
