- Wed Jul 11, 2012 8:43 am
#310594
is it worth 1700? might be to someone who can do the work. but if you gotta send it somewhere or pay someone to have it done, you might look the other way.
is a headgasket easy to do? imo, yes. but i know how to do one. since youre asking is it easy, im willing to bet you do not.
if you're buying it as a project, then id do it. save up some cash, buy a service manual (haynes for expample) the replacement parts (advance, etc will work just fine in your case). youll for sure need a headgasket, valve cover gasket set, timing belt and water pump kit (should come with water pump w/gasket, timing belt, tensioner and spring), intake manifold gasket and exhaust manifold gasket, new cylinder head bolts (Honda/Acura part only).
Take the head to a reputable cylinder headshop to have it checked for warpage and/or any other issues.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
