B16, B18, B20
By Moez_cx
#309749 so i bought the skunk2 alpha throtle body 70mm and when im installing iit says that im suppose to connect the coolant by pass hose? yet my other throttle body (no name aftermarket) has none of these ports for the coolant bypass hose so do 1 do i need it? and if i do where are the coolant by pass hose even located on a b16 ?
By Moez_cx
#309755 bump!
By blk92hb
#309768 You don't need to. I unhooked it from my stock tb. Its to help warm up the coming air
By Moez_cx
#309813 so i finally got the throotle body on and the i made to my job now the problem it feels like there a dead spot between 1.5 k - 2k revs as soon as i decelerates it just goes straight down to idle and the same if im accelerate the engine jerks like its fluctuating do i need to adjust my throttle cable because there could be some play? also if i tried to keep the engine in that rev range it just fluctuates help me :?
By Moez_cx
#309824 bump
