B16, B18, B20
By kapow
#309631 Just wondering what cams guys would recommend
After months of looking for ITR cams, I decided to look for other brands which may be similar
B18C Block
P30 Pistons
P72 Crank
P72 Rods
B16A Head
B16A Cams (not sure if it would suit the compression
11.2:1 is the compression read out at http://tachedout.com
By poorman type-r
#309636
kapow wrote:Just wondering what cams guys would recommend
B18C Block
P30 Pistons
P72 Crank
P72 Rods
B16A Head
I think Skunk 2 Pro 1's got the same results as the Type-R cams did on the dyno. So those would simulate them exactly.
By kapow
#309667 Thanks man :)
By bigpunn421
#309790 skunk 2 pro 1s are good
if its a track car bump the compression up and get aggressive cams with ti valvetrain
By kapow
#309853 That's what the P30 pistons are for! :)
By 92dxeg
#309870 would ctr cams and pro1s be the same thing cuz i have a gsr block crank 81.5 12.5.1 cp b16 head gsr cams looking to build a gsr head on the side what should i use
By kapow
#309932
92dxeg wrote:would ctr cams and pro1s be the same thing cuz i have a gsr block crank 81.5 12.5.1 cp b16 head gsr cams looking to build a gsr head on the side what should i use
According to posts on hater-tech, CTR/ITR cams are similar to Skunk2 Tuner 1 cams
By bigpunn421
#310028 pro 1 cams are alot beter than itr cams. 92exeg i think you have the tuner/pro series cams confused.
tuner 1s are similar to itr but pro 1s are different
http://store.skunk2.com/engine-tuning/c ... hafts.html tuner 1s
http://store.skunk2.com/engine-tuning/c ... hafts.html pro 1s
heres a good write up http://www.evans-tuning.com/blog/2009/0 ... whp-gains/
