By Ontario_EG - Thu May 10, 2012 1:48 am
#304452
Hello Gang New to the Forums and saying HI all over the place!
So... My D is dead i think or getting to the point it needs to go to ZZZZZ
I picked up a B18B1 out of a 95 Teg.. Well a friend gave it to me. Distributor is missing no exhaust manifold or starter. or trans and so on.
I plainly need advice.
I picked up a B Series Transmission so far and also have the complete engine wiring harness with the engine.
So reading up I belive I am going to need to collect the obvious:
-Axles,Shift linkages,PCM,mounts,clutch/flywheel/distributor and header.
My HUGE questions is.. I know the answer on the parts I require but I am thinking more into it as a permanent swap for my EG and I plan to keep this car for a long long time.
THE WIRING!
Would this teg hardness plug and play .. and just swap in the teg pcm?
Also
I was looking at Hassport Shifter linkages and axles Good? Or if I am not really going high power is it a total waste? Keep in mind I might turbo in the future but definetly not a high boost situation.
Also clutch? I can pick up a Exedy OEM grade clutch for $160.00... Bad idea? Or should or there some suggestions
HELP ME GANG! I soon need to get this B18 in.. Currently in the process of cleaning the motor up and head.. with all new gastets and seals..
THE WIRING!
Also
1992 Honda Civic EG DX (WIP)
