- Sat Mar 10, 2012 4:34 pm
#297716
93 hatch dx throwing codes 9 10 and 43. 9 says cylinder sensor 10 says intake temp sensor and 43 fuel supply system. what does it all mean!!!lol thanks for any info guys btw just did a jdm b16 swap the previous owner was using a apexi vafc II with a p28 but i found a p30 and opted to use it seemed much simpler.
code 10 means the sensor or wiring is bad. check both and go from there. also, try a different ECU. if the IAT has been shorted then it can mess up the ECU as well.
code 43 is fuel system, check fuel pressure check the injectors.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
