- Thu Feb 02, 2012 11:13 pm
#293088
I've been gone for a while, but I'm back with a Frost White 1998 GSR. I have recently (two weeks, 300ish miles) rebuilt the engine with the following:
81.25mm ITR pistons
ACL bearings
Skunk2 IM
Skunk2 Alpha Series header
Skunk2 Alpha Series 66mm TB
Injen CAI
Buddy Club 2 layer head gasket
Mizu radiator hoses
P28 ECU chipped with Crome on a B18C1 with Skunk2 IM base map
All of the seals and gaskets are new from the dealer except for the head gasket.
Compression ratio calculates out to 11.39:1, static.
Problem is as stated in the title. I have a fluctuating idle that is acting like a vacuum leak. When I come to a stop light, I throw it in neutral with my foot off the clutch. It will fluctuate from 1100-1300rpm. I have bled the cooling system twice, but found another small pinhole leak and will be fixing that and bleeding the system again in a few minutes. I replaced the stock throttle body with a Skunk2 Alpha series 66mm TB thinking that the B16 TB I had bought had a leak at the throttle plate shaft. MAP sensor, IAT sensor, IACV, and TPS all have new gaskets and o-rings as required. I Hondabonded (new verb, use it and spread it) the MAP sensor, IAT sensor, and the TPS to insure that those were not leaking.
I have a CEL for the IAT sensor. I'm thinking that I might have either extended the wrong wires or my solder joints are shit. That's a different problem, I imagine.
I know that the P28 looks for a FITV that I do not have, nor do I have an electrical connector for it on my wiring harness. Not sure if that is causing the fluctuation, just throwing that out.
Any ideas?
81.25mm ITR pistons
ACL bearings
Skunk2 IM
Injen CAI
Mizu radiator hoses
Any ideas?
