B16, B18, B20
By ilovemyeg4
#287156 Now I have read a lot of forums on here but I don't think enough. The one major question I have is, can you simply just drop a B series engine into a 1995 Civic EG with just some new mounts and trans? If not what would I need and what needs to change. Thanks!
By ilovemyeg4
#287807 Thanks mate :)
By aidan/eg5
#287815 eg4 is running sohc vtec so its not that difficult you'll need engine and all ancilaries to go on it including inlet mani, exhaust mani, distributor, ps pump alternator, ht leads, rad, hoses and transmition. you'll also need drives and half shafts gear linkages hubs. and ecu your own loom will do but you'll need to run a wire to ecu from knock sensor and your own injectors will do as long as the engine your putting in is obd1. If your putting in an engine running on obd2 you'll need a new engine loom and a jumper harness for ecu.
