- Sun Nov 06, 2011 1:34 am
#280349
I'd check into SRP pistons. I'm also a fan of Eagle rods. They're both quality aftermarket parts!
- Sat Nov 12, 2011 9:47 pm
#281219
So sfter doing research and stuff i came 2 the conclusion of getting 1 of these 2 set. Wat do you guys think? Which 1 is better and should i just get the pistons and arp rod bolts n use my stock rods? Help please!!! http://realstreetperformance.com/store/ ... 0-446.html
Or
http://realstreetperformance.com/store/ ... 20-90.html
Or
- Sun Nov 13, 2011 2:53 am
#281251
the first might be the best one.
only because the second one looks like its for the stock ls and the b20/v
what compression are you looking for?
your car is your story, dont let someone else write the book.
91 s10 (sold)
92 civic si with jdm b16a (Sold) http://civic-eg.com/viewtopic.php?t=13460
99 civic lx (current) viewtopic.php?f=63&t=30348
91 s10 (sold)
- Sun Nov 13, 2011 7:11 am
#281281
I like the 1st 1 as well. Not sure wat compression i wan't i just wanna make 200+hp.
blk92hb wrote:the first might be the best one.
- Sun Nov 13, 2011 4:08 pm
#281313
i would go 10.5 so you can still run pump gas. 11 max
91 s10 (sold)
91 s10 (sold)
- Sun Nov 13, 2011 9:10 pm
#281369
So which 1 should i get?
149232
B18A1/B1 w/ VTEC HEAD
81.00mm (Standard Bore)
10.3:1
149233
81.25mm (+.010" Overbore)
10.3:1
149234
81.50mm (+.020" Overbore)
10.3:1
149226
10.5:1
149228
10.5:1
blk92hb wrote:i would go 10.5 so you can still run pump gas. 11 max
149232
10.3:1
149233
10.3:1
149234
10.3:1
149226
10.5:1
149228
10.5:1
- Sun Nov 13, 2011 9:58 pm
#281373
you can run pump gas up to 12.5:1CP, just so you know
|^^^^^^^^^^^\||____
| The STFU Truck |||""'|""\__,_
| _____________ l||__|__|__|)
Panda Crew Member #24
Coupe Crew #9
Team XXX Racing
Coupe Crew #9
Team XXX Racing
- Tue Nov 15, 2011 12:55 am
#281473
Ok guys so here is my build plan: SRP pistons with Eagle rods. Pistons come with rings, wrist pins, and locks. Eagle rods come with arp rod bolts. As of now my plans r 2 just drop everything in n go, but the real question is, Do i have 2 do anything that is mandatory 2 the block for the piston n rods 2 fit correctly in my block? Please need help. I really want to have everything first b4 i start throwing stuff on.
- Tue Nov 15, 2011 1:54 am
#281476
Id suggest honing the block.
|^^^^^^^^^^^\||____
Coupe Crew #9
Team XXX Racing
Coupe Crew #9
Team XXX Racing
- Tue Nov 15, 2011 1:55 am
#281477
just take it to a reputable shop and depending on wat he recommends you can go from there. I def recommend honing though.
|^^^^^^^^^^^\||____
Coupe Crew #9
Team XXX Racing
Coupe Crew #9
Team XXX Racing
- Page 2 of 4
- 1
- 2
- 3
- 4
