B16, B18, B20
By egdan
#277645 hi i have a b16a2 with p30 ecu can i run throttle bodies on it with no remap or will i have to map it if so wat would it run like would it be a big bhp gain . thanks
By bks84
#277664 no tune would be required if you stepped up to a 68mm (blox, OEM ITR, skunk2, etc) however if youre wanting to run individual throttle bodies (like TWM, Jenveys, Kinsler, etc) then a tune would be required.
By poorman type-r
#277665
egdan wrote:hi i have a b16a2 with p30 ecu can i run throttle bodies on it with no remap or will i have to map it if so wat would it run like would it be a big bhp gain . thanks
You won't really see a big horsepower gain, but you might feel a little difference. If you want a major noticeable difference pick up a set of Skunk2 cams or somethin.
