- Mon Oct 03, 2011 3:46 am
#275869
K so ya im new here, hey, but anyway. I currently have a 92 DX sedan, (d15b7 unfortunately) and a 94 Teg LS, both 5 speed. I have both Full running driving cars at my disposal. I read up on how "easy" it is on swapping the b18. What im asking is if Im correct by assuming I need the following for the whole swap.
LS Motor
LS Tranny(both are hydro)
ECU
Axles
Linkage
Teg mounts.
If im wrong in assuming i dont need anything else i would like to know. I followed a walkthru posted on here but before i start tearing both of my cars apart i wanted to make sure the process is as straight forward as it sounds lol. Just seems too easy to me is all so wanted to make sure.
Heres the post i was reading
Posted: Sun Oct 01, 2006 9:54 pm Post subject: The ol b18 swap
This swap isnt really that hard to do at all!!! all you will need are the following:
Integra motor mounts!!!!
Integra shift linkage
Integra(bseries) axels
and a integra ecu pref. onethat is obd1 since your eg civic is already obd1..otherwise you will have to purchase a conversion harnessfrom either obd0 to obd1 or obd2 to obd1.
This swap really is not that hard at all. All you need to do is undo your harness by the six plugs. three on each side of the motor.
once those are out make sure you have everything disconected and out of your way. ex. exhaust manifold. radiator...etc.
Then what you will want to do is take of your shift linkage and take out your axels.
then what you want to do is just loosen your motor mounts and hook up your chain to using two sterdy mount holes to lift your motor up and out of your car.
Then take out your bolts and begin to lift your motor out of the car (you might need to jock it around a little bit but it will come out.)
The start with you new b series motor and work your way backwards from which you started.
This is a good learning project. If you work on it non stop you should be able to get it done in three to four days.
If you have any questions or comments pm me i check it often.
--Kevin
_________________
Any help is appreciated
LS Motor
ECU
Axles
Linkage
Teg mounts.
--Kevin
_________________
