- Sat Sep 24, 2011 10:13 pm
#274262
This problem has been going on for many months but didn't really bother me until yesterday where it jus happens every single time I take off. So I'm a little worried about my hatchy now.
Ok here's everything it does; my car jerks violently as if I'm tapping on the gas rapidly, and then once the jerking stops, I lose sagnificant amount of power for like 20-30 second,then power restores like nothing happened. I have to keep light on the gas or it will jerk again.
-Happens especially when shifting to second gear.
-happens only when engine and engine bay is hot(not overheating, texas weather)
-when shifting under moderate to heavy loads.
-will jerk if not shifting smoothly
-will not jerk if I shift very smoothly into second,third, etc, with light gas input.
-never happens when engines is still warming up and cold
-I'm not sure if this problem is related to my bouncing idle when cold.
-no I don't have bad transmission, fresh trans fluid less than 2000 miles
-while driving with the loss of power after the jerking, if I try to give it a load it will jerk.
-somethimes up shifting helps it get out of the power loss phase.
I don't kno what the hell could be the problem.
I thought its my distributor, nope I have two of them swapped them both, did the same thing, one is new too.
I'm thinking it could be my o2 sensor but I'm nt sure of the symptoms of a failing o2 sensor.
Maybe a too hot intake tempuraturem I don't kno this is soo hard to diagnose. And I'm actually good at diagnosing. My friend has the same exact problem and he has an LS. He's clueless too.
So pretty much if I get this solved u solve another persons problem too lol.
Thanks for taking the time to read this, I hope to get any info that will lead to solving my issue, thanks guys.
